AW: Nokia 5230 nach Update ohne Funktion
Es gehts aber keine ._. .
Wo kann ich die fehlende Datei herbekommen?
Und ämmm wenn ich das bei anderen Modis ausprobiere kommt auch dieses Problem >>http://img.mu/1kZSqc
1. Make sure USB cable, Battery and charger are removed from device.
2. Insert USB cable to device
3. Insert Battery to device
4. Insert Charger to device
--- Press phone's power button! ---
Loading secondary boot code: 15232 bytes
Secondary boot loaded
Loading update server code: 2639925 bytes
Update server loaded
Asic CMT: Verifying communication to device...
Asic CMT: Start programming 820583 KB...
Asic CMT: Partitioning RM-588_50.0.001_prd.core.C00
Asic CMT: Partitioning area 1...
Asic CMT: Erasing RM-588_50.0.001_prd.core.C00
Asic CMT: Erasing area 1...
Asic CMT: Erasing area 2...
Asic CMT: Erasing area 3...
Asic CMT: Erasing area 4...
Asic CMT: Erasing area 5...
Asic CMT: Erasing partition 0x0000000A...
Asic CMT: Erasing RM-588_50.0.001_prd.rofs2.V02
Asic CMT: Erasing RM-588_50.0.001_C01_prd.rofs3.fpsx
Asic CMT: Erasing RM588_50.0.001_000_000_U001.uda.fpsx
Asic CMT: Programming RM-588_50.0.001_prd.core.C00
Asic CMT: Programming 0%
Asic CMT: Programming 2%
Asic CMT: Programming 4%
Asic CMT: Programming 6%
Asic CMT: Programming 8%
Asic CMT: Programming 10%
Asic CMT: Programming 12%
Asic CMT: Programming RM-588_50.0.001_prd.rofs2.V02
Asic CMT: Programming 14%
Asic CMT: Programming RM-588_50.0.001_C01_prd.rofs3.fpsx
Asic CMT: Programming 16%
Asic CMT: Programming RM588_50.0.001_000_000_U001.uda.fpsx
Asic CMT: Programming 18%
Asic CMT: Programming 5230_SW_MC037_DACH_2G_4.0.fpsx
ADL LDR: Resending Prepare for Write Request....
ADL LDR: Error writing to target address 0x00000000, Size 0x00100000
Asic CMT: ERROR Programming 5230_SW_MC037_DACH_2G_4.0.fpsx Block 0. Unable to continue flashing.
Asic CMT: Error in sending data from 5230_SW_MC037_DACH_2G_4.0.fpsx.
Protocol 1: Error during Flashing. Unable to continue.
Unable to flash phone 0x84012283
All operations completed
Product flashing failed.
Und denn erschien dieser Fehler :
ImageShack® - Online Photo and Video Hosting
Ich brauche dringend Hilfe .
Entweder ist die DACH Datei fehlerhaft oder nicht vorhanden.
Wenn die DACH Datei vorhanden ist, mal über die anderen Funktionen zu flashen.
Leider habe ich keine ahnung vom Flashen ich habe es hin und wieder gemacht ging auch gut .
Könntest du mir helfen .
ruf mich morgen im laufe des Tages einfach mal an.
Dann machen wir ne Teamviewersession und ich schau mir das ganze mal vom Laden aus an.
Hat jemand Erfahrungswerte und Lösungswege mit dem neuestem Update für Nokia 5230 das man per PC machen muss? Ich habe mein 5230 und das meiner Tochter mit dem neuestem Update auf den neuesten Stand gebracht. (Datei hatte eine größe von 150MB) Seitdem Funktionieren beide Geräte nicht mehr Richtig! Sie stürzen Ständig ab und Reagieren oft nicht auf Eingaben.
Ein Hardware-Reset hilft leider nicht. Würde fast sagen, das die Handys jetzt Unbrauchbar sind! Bin für Tips und Lösungsvorschläge dankbar!
Gruß prepaid.
erst mal finde ich es klasse was hier alles so gepostet wird aber ich wäre froh wenn ich mal so weit kommen würde, dass mir Phönix nen Fehler melden würde...
zu meinem Problem:
Ich hab Phönix nun schon auf div. Systemen installiert (XP; Win7 x86; Win7 64) startet sauber ohne probs aber überall das selbe ...
Verlauf:
Alles sauber mit navifirm geladen und einen Ordner erstellt (RM-588) unter Products usw.
Die Dateien müssten auch die richtigen sein, denn mein Modellcode (059C4M1) war ja leicht zu finden:
RM588_059C4M1_50.0.001_001.dcp
RM588_059C4M1_50.0.001_001.spr
RM588_059C4M1_50.0.001_001.vpl
RM588_059C4M1_50.0.001_001_signature.bin
Wenn ich nun im Phönix unter "Open Product" mein RM-588 suche ist nix da... und zwar wirklich keines der 5230, wenn ich auch über den Namefilter nach "Nokia 5230" suche. Ein RM-58, ein RM-586 aber kein 588er???
kann mir da jemand weiterhelfen??
Torsten
hallo torsten,
wende dich mal per PN an den kollegen funshopper_de und verweis ihn auf deinen post hier, ich bin mir sicher er kann dir weiterhelfen
in diesem sinne
proofman
und wo ist die anleitung?
welche?
in diesem sinne
proofman
vielen dank für die beschreibung !
aber unter windows 7 64 bit scheint es nicht zu gehen.
werde es gleich mal bei meinem bruder an einem windows xp rechner versuchen.
will dann mal hoffen das es gut geht !
werde mich später nochmal melden.
( mein rechner ist ebenfalls beim updaten meines 5230 abgestürzt ) eine ganz kurze vibration noch beim einschalten ! mehr nicht !
mfg: elvarani
Habe das selbe Problem wie Lennoxx. Habe alles installiert und den Ordner RM-588 sowohl im Ordner Products, als auch im Ordner CommonFiles/Nokia/DataPackage/ erstellt und mit der aktuellsten Firmware gefüllt. In den Optionen bei Product Location auch beide Ordner angegeben. Jetzt habe ich jedoch im Reiter Open Product garnicht die Auswahlmöglichkeit von RM-588, lediglich RM-58 steht zur Auswahl. Wenn ich mit RM-58 weiter mache, kommt im Reiter Firmware Update bei Klick auf die Auswahl der Firmware die Fehlermeldung, dass DP1.0 und DP2.0 nicht gefunden werden. Ich denke das hängt mit der anfänglichen Auswahl von RM-58 zusammen. Kann mir jemand weiterhelfen?
habe versucht mein Handy über Phoenix zu reanimieren. Paket RM-588_51.0.002 Handy 5230
Flashing started
Creating product data items list
Product data items list created
Backup not required
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
Asic CMT: Start programming 155998 KB...
Asic CMT: Partitioning RM-588_51.0.002_prd.core.C00
Asic CMT: Erasing RM-588_51.0.002_prd.core.C00
Asic CMT: Erasing RM-588_51.0.002_prd.rofs2.V02
Asic CMT: Erasing RM-588_51.0.002_C01_prd.rofs3.fpsx
Asic CMT: Erasing RM-588_51.0.002_000_001_U001.uda.fpsx
Asic CMT: Programming RM-588_51.0.002_prd.core.C00
Warning: Unexpected Message received from phone. ID 0x20
Asic CMT: Programming 20%
Asic CMT: Programming 22%
Asic CMT: Programming 24%
Asic CMT: Programming 26%
Asic CMT: Programming 28%
Asic CMT: Programming 30%
Asic CMT: Programming 32%
Asic CMT: Programming 34%
Asic CMT: Programming 36%
Asic CMT: Programming 38%
Asic CMT: Programming 40%
Asic CMT: Programming 42%
Asic CMT: Programming 44%
Asic CMT: Programming 46%
Asic CMT: Programming 48%
Asic CMT: Programming 50%
Asic CMT: Programming 52%
Asic CMT: Programming 54%
Asic CMT: Programming 56%
Asic CMT: Programming 58%
Asic CMT: Programming 60%
Asic CMT: Programming 62%
Asic CMT: Programming 64%
Asic CMT: Programming 66%
Asic CMT: Programming 68%
Asic CMT: Programming RM-588_51.0.002_prd.rofs2.V02
Asic CMT: Programming 70%
Asic CMT: Programming 72%
Asic CMT: Programming 74%
Asic CMT: Programming 76%
Asic CMT: Programming 78%
Asic CMT: Programming 80%
Asic CMT: Programming 82%
Asic CMT: Programming RM-588_51.0.002_C01_prd.rofs3.fpsx
Asic CMT: Programming 84%
Asic CMT: Programming 86%
Asic CMT: Programming RM-588_51.0.002_000_001_U001.uda.fpsx
Asic CMT: Programming 88%
Asic CMT: Programming 90%
Asic CMT: Programming 92%
Asic CMT: Programming 94%
Asic CMT: Programming 96%
Asic CMT: Programming 98%
Asic CMT: Programming 100%
Mobile device flashing completed.
Waiting for phone to boot up
Bootup successful
Verifying communication to product (before flash finalizing)
Communication verified
Product code changed
Doing factorysets
Factorysets complete
Loading default data to phone
Getting Data Package
Reading product state
Starting backup/restore sub-procedure: data item pre-delay
data item pre-delay
data item pre-delay
Sub-procedure completed: Succeeded., result code: 0
Starting to backup/restore data item: ProductProfile, version: 1.1
Data Item backup/restore completed: Succeeded., result code: 0
Starting backup/restore sub-procedure: data item post-delay
Backup/restore result: 0 out of 1 items were not backed up
Default data loading complete
Stopping all operations, returning phone to default mode
Firmware updating succeeded.
Also theoretisch erfolgreich, Handy gibt trotzdem nur ein kurzer Vibrieren von sich und sonst nichts Selbes ergebnis, sowhl bei refurbisch als auch sw reset mit dead usb.
Für Hilfe wäre ich sehr dankbar.
